Flash won't work
I’m on a Mac using High Sierra. I’ve installed Brave and then I followed the link in Brave to install the Flash plug in, and I’ve now installed it 3 times. Each time it says that it has installed. I’ve tried closing the browser and opening it back up and I’ve tried rebooting my machine. Nothing works. Flash doesn’t work on Brave as far as I can tell.
@bkarlan
Are you willing to share what site you’re trying to view with flash? If you don’t want to post publicly you can private message it to me.
Also, do you have Widevine enabled (on the same page in Preferences)?
Thanks,
Lauren
closed #3
