Feedback - Double Click in URL should not resize window
In every other browser, if I double/triple click on the URL it selects the entire URL string.
With Brave on MacOS 10.13.1, if you single click into a URL and get the cursor to modify the URL, then want to replace the whole string, the doubleclick causes a window resize instead of selecting more of the string. Same for triple click.
The URL text box should be excluded from window click-resize operations like it is with other browsers.
closed #2
