When I make a research and go to “Images” tab, nothing appears after loading indicator finish to spin. Here’s an example (in French version) and what I have in the inspector :
Failed to load resource: the server responded with a status of 404 ()
The resource was preloaded using link preload but not used within a few seconds from the window’s load event. Please make sure it has an appropriate
as
value and it is preloaded intentionally.
When I click on the urls of the warnings, I can find pictures in the sources.
Just a precision, i try to update Brave but this doesn’t make any change.
It’s difficult to say but i simply make a research and then go in pictures tab.
I should have the images displayed.
Brave Version: 1.58.131 Chromium 117.0.5938.92 (Build officiel) (64 bits)
