For some reason and all of a sudden, every site I open (literally every site) NEEDS to be refreshed in order for it to load. Otherwise, it will simply not load at all and the wheel will keep spinning. Does anyone have a solution to this?
Thanks.
Thanks.
Your DNS problem, check your DNS on your router or whatever you use.
Also check it in brave browser settings page in security. Make it cloudflare 8.8.8.8
