Hi, when I try to add one more website, it tells me that I have reached the limit and to contact support. I even deleted a website to add one more but it keeps coming up with the same error.
No answer or solution?
Similar topic with Brave support response:
Specific post from support:
You should DM support staff with “the email linked to your Creators account” and see if they can help. If you do not get a response, then submit a request for support using the form linked below. Or your could do both.
Hope this helps. Take care.
Thx a lot ! This issue for me is resolved
You should mark your post as the solution so that other community members and/or Brave support know your issue is solved.
Thank you for your response. I sent the message but still no response. I will try the help center.
@marifer Submitting a request is probably a good idea at this point. Payout cycles can be a really busy time for Community moderators.
I am still going to go ahead and tag @Mattches and @steeven. They may post to your topic if they have any additional options or information.
