Do you recommend closing it? I want to see the most ads for profit
No, thatâs not necessary, the brave shield doesnât interfere with the brave rewards
OK
At first, I noticed my ads were low, and now they are increasing. Could this be explained by my lower earnings?
Itâs been 7 days since I signed up for a total of 17 cents. It means I earn $ 1 a month and thatâs low
@TarqSultan1 each ads has different BAT value set by the advertiser
another note do not think that ads will give you tons of money unless if BAT price sky rocket like bitcoin
the only rule is that the users get 70% of the ads value and 30% go for brave company
if you need more then if you have site /channel then join the creator program and hope that your user tip your site
for more info about that check this https://creators.brave.com/
Youâve received 18 ads in one week. Thatâs not bad for your country. The ads donât pay a lot (itâs up to the advertiser), so donât expect to gain a lot of money this way. Donât confuse the Brave Rewards ads (popup notification at the bottom of your screen) with the Web site ads that Brave blocks. You would get no rewards at all by allowing the Web site ads, so itâs better to allow Brave to block them.
