rep
July 6, 2021, 6:45pm
1
Ddg settings reset automatically after a couple of days
Customize Duckduckgo settings
wait a few days
Reset of the settings.
Settings should be saved and not reset unless cookies or data are cleared
1.27.1
Hey @rep !
Can you check your Shield settings as well as if you are clearing browsing data when exiting Brave?
You can do this by going to brave://settings/clearBrowserData
and clicking On exit
Porridge
rep
July 6, 2021, 7:24pm
3
Thanks for the quick reply! I can’t find this setting on iOS and I haven’t been clearing the data for a while
system
Closed
August 5, 2021, 7:24pm
4
