Duck duck go problem
I’ve :honeybee: using Brave for several months and think it’s great. However suddenly it started to go to duck duck go automatically instead of Google. I know it uses Duck for"private" searches but I wasn’t using that. I’ve had to uninstall and start again. What’s the explanation?
Hi @Gwydion,
It’s for Android right? Can you check your search engine settings first?
Yes, simples! Thanks for the clarification which I’ve now carried out.
closed #4
