Dual screen problem: Brave window leaks on the other monitor
I have two physical monitors and when I put the Brave window fullscreen on one of the monitor, the window “leaks” onto the other screen: I can see a vertical white line on the other screen.
It’s not only ugly but is also a problem because moving the mouse next to the edge of the other monitor will show the “resize” mouse pointer. Clearly, the window seems to be a bit larger than my monitor’s width when it’s put fullscreen.
This seems to be the same problem as the one reported here: Dual screen problem
I am running Windows 10 (build 17133) and Brave version:
Brave 0.22.13
V8 6.5.254.41
rev a8cfb16
Muon 5.1.2
OS Release 10.0.17133
Update Channel Release
OS Architecture x64
OS Platform Microsoft Windows
Node.js 7.9.0
Brave Sync v1.4.2
libchromiumcontent 65.0.3325.181
closed #2
