Can you please tell me what version of windows you’re using at this time? Additionally, does it happen when you use a different mouse and/or the mouse/trackpad? If so, does it happen in other browsers/applications?
My windows version is 21H2 (2021.11.29). I am pretty sure this is a technical issue and not my mouse because when I play games or use discord this error does not occur. This problem can be found in other browsers too.
@Mogyesz,
Then the issue is either with Windows or the mouse itself, given that this behavior occurs in other browsers and not just Brave. I would again recommend testing the behavior with a different mouse.
