Does the Brave community advocate using searX search engine?
( Is one considered more secure than the other?)
When I try to add in settings mode webTorrent, Hangouts and Manage Extensions section covers over part of the search engine entry area
Desktop ver:
Version 0.62.50 Chromium: 73.0.3683.86 (Official Build) (64-bit)
macOS High Sierra
Version 10.13.6
iMac(21.5-inch, Late 2009)
Processor 3.06 GHz Intel core two duo
Memory 12 gig 1067 MHz DDR3
The first one added automatically looks correct. The second entry looks like manual entry which won’t work correctly as there is no query parameter passed (/search?q=%s or ?q=%s). I’d suggest you remove the second one.
