Does not render sky.com/shop correctly
Browser does not render sky.com/shop correctly, cannot scroll down to see full page
Enter web address sky.com/shop, try and scroll down the page. Initially you can see the full page rendered but once it’s fully loaded you can no longer see it and scroll down
Full page rendered
1.14.84
Running on Linux elementary OS
Hello @fireplex
it work fine from my side here and i am on linux also but centos
could you try to disable all exension and try again
Tried disabling extensions, same issue. Also tried from a private window.
But, ooks like a brave shields issue, if I turn that off for the site it renders fine…
could you enable the shield again then allow all finger print
Yes that worked, cheers.
glad it works and you welcome :slight_smile:
