Display Problem: Everything is blurry
windows
bug
DESCRIPTION
All text is blurry until I roll over with the cursor. Then it will snap into normal quality.
SPECIFICATIONS
Windows 10 64bit
Nvidia 1070 ti
|Brave|0.19.139|
|rev|99aa17d|
STEP-BY-STEP
no steps required, issue present on launch
Fixes Attempted
Watied for new versions (issue persisted)
Multiple reinstalls (including wipe of appdata./local/brave directory)
VIDEO OF ISSUE
Video host appears to have gone down.
VIDEO OF ISSUE
#3
What version of Brave are you using? You can find this in about:Brave
#4
The brave version is 0.19.139
#5
Some say to adjust your DPI by Right-clicking your desktop > Personnalization > Bottom left, click Display > slide the slider to “Smaller”. Some people say it works. Hope it helps!
#6
I do not have that setting available. However, this monitor is a 144Hz high resolution display so the issue may be related. Any other suggestions? Here are some screenshots of my configurations, all settings are default/native.
Incredibly blurry text
#7
Any ideas at all? Brave is unusable with this bug
closed #8
