difference between uphold and brave
I sent a request to the support of brave 20 days ago but no response, so I come to tell you about it here. I work on 2 PCs and I only get the rewards for one !!! I send you a screen of uplhold and brave and you will see the difference. Thank you for your reply! and to rectify this problem, I already lost 20 BAT when an update changed my parameters and I am at more than 9 bat
Thank you for reporting! Please DM with the following information:
  • Copy/paste your Wallet ID (found on brave://rewards-internals)
  • Your OS and Brave version (first three lines in brave://version)
  • A screenshot of your Rewards panel in Settings --> Brave Rewards.
This will help to speed up the troubleshooting. Thank you in advance!
