Brave should show the changed value. Brave Version( check About Brave):
Brave 0.68.132 Chromium: 76.0.3809.132 (Offizieller Build) (32-Bit)
Überarbeitung fd1acc410994a7a68ac25bc77513d443f3130860-refs/branch-heads/3809@{#1035}
Betriebssystem Windows 10 OS Version 1809 (Build 17763.195)
Did it happens only for “Device recognition”, @Johann ? How about other shield settings? Did you change the global shield settings or per-site shield settings (via Brave icon at URL bar)?
@Johann,
Have you cleared your browsing data and/or do you have any data to be cleared on exit (Settings --> History --> Clear Browsing Data --> [On Exit])?
@Johann,
I believe that’s the problem then – we have an open issue right now wherein Shields settings are wiped/reset alongside browsing data. We’re working to decouple these data so that it can be wiped without effecting Shields settings:
