Detail Guide on how to fix Error 11
Hello, I recently created a topic surrounding an issue I had with Brave on my MacBook after said laptop had a software update.
Now recently I discovered one of the issues was that for some reason the setting to block scripts had been enabled and that fixed a couple of them, but not all of them.
Certain sites such as sci.news fail to load at all and as of today, in my settings it says that there was an update error, specifically (error 11), and I believe this is likely the reason for some broke sites.
This is something I really want fixed as soon as possible as I need to work through some stuff for job hunting and I’m not sure if what I need will work, so if someone has a detailed guide on how to fix error 11, let me know.
If there are any questions that can help narrow things a bit I’ll be glad to try and remember as much as can. But for starters today when I was in my setting Brave said that it needed to relaunch to update fully, however this didn’t help and is where the new error 11 came up. Please anyone help, even if it’s forcing a Mac software update or just waiting for one I need something.
