Default zoom level percentage persistent but behavior output not
Ubuntu 18.04 LTS
Brave: 0.22.727
After setting the Default Zoom Level in Preferences (125%), after closing and re-opening Brave, the Zoom Level of the browser toolbar reverts to default size, but the Default Zoom Level indeed reads 125%.
This can generally be solved for that session by selecting 100%, then selecting the desired 125%.
Thanks for any insights!
@openfield
If you go to Preferences > Advanced, could you try setting ‘Toolbar and UI elements scale’ to be something like ‘Larger’ and see if that sticks?
#3
That seems to have solved it. Thanks!
closed #4
