Dashlane sign-on does not work
The latest update seems to have resolved the issue for me.
Win 10-64
Brave File Version 8.1.6.0
app-0.24.0
Logging on to myuhc.com, but Dashlane is failing to provide links to supply the login/password. It was necessary to copy/paste the data from Dashlane.
I am also experiencing a greyed-out and non-functioning Dashlane extension, if I turn on an off in settings I can use workaround but this is not useful for constant use:
Dashlane version: 6.4.0
Brave: 0.25.2
V8: 6.9.427.23
rev: 8ea2a9ce5ca329478186e6393e07f1cf87d34a22
Muon: 8.1.8
OS Release: 10.0.17134
Update Channel: Release
OS Architecture: x64
Node.js: 7.9.0
Brave Sync: v1.4.2
libchromiumcontent: 69.0.3497.100
Hi.
i don’t know what “Dashlane” is, but you are using Brave: 0.25.2, but the current version is: 0.55.22 Chromium: 70.0.3538.77 (official build)
Follow these instructions, and see if this might solve the problem: :slightly_smiling_face:
@Mattches: Maybe you should point out somewhere that there is a new version of Brave, but it can’t yet be installed via the updater in the browser? :lying_face:
Translated with www.DeepL.com/Translator
