hello i disconnected my uphold to my creator account and after i reconnected im getting an error i talked to uphold but they redirect me here i hope you can help me
please see the attached screenshot for your reference
take note i dont have any other creator account only this one
Nothing I guess, they’ll get back to you as possible. Since it is still a Sunday in the US, and since Brave’s team works on weekdays only so its possible it could be a while till you get a reply from Brave’s team
@steeven@Mattches does region restrictions affects brave creator accounts? I’m from the Philippines and I can’t reconnect my uphold after I changed my password because it required me to reconnect my wallet it shows that I have multiple brave creator account which I don’t
I think answer is NO because I am also unsupported region and i received creater payout time to time. As per i understand problem is. you said you are disconnected the uphold but as per i know it’s still connected to uphold (upto 90day from disconnected). You need manualy remove your creater account.
Follow this steps:-
login in uphold ( app/site)
Go to menu and select integration
Select brave reward than delete/unlink
Than enter security keys(if applicable)
