ClearURLs for uBo and reddit problem
I have a problem with brave (any version: stable, beta and nightly) with ClearURLs for uBo unofficial. If I import these filtering rules on brave, I can’t open reddit as it continuously reloads the page while everything works fine with firefox (any version) and ublock origin.
This is OK:
https://www.reddit.com/r/privacy/comments/1dmhtwy/the_orwellian_reframing_of_privacy/
This have a problem: https://redd.it/1dmhtwy
Screenshot of the ad as it appears in Brave:
Did the issue present with default Shields settings? No, only with custom filtering rules
Does the site function as expected when Shields are turned off? Yes
Does the ad appear when using a Private window as well? Yes
What OS are you using when you see the ad? GNU/linux
Brave version (check About Brave): 1.69.40
Probably related?
Using the rdt param on reddit causing issues on chromium/Brave. Would look at other params being applied.
Right, I added to custom filters:
!#if env_chromium
||reddit.com^$removeparam=rdt,badfilter
!#endif
The problem is solved.
