Bug report
Steps to reproduce:
On a Surface Go tablet (or similar) using touch or stylus, tap the Claim Reward button and attempt to drag the triangle into the indicated shape in the subsequent test.
Triangle drags with touch/stylus as it would using a mouse cursor.
Actual result:
Triangle does not respond.
Request:
Please add support for touch and stylus on this class of device.
@nicojoco This is an issue that pops up now and then. An open issue report for a Surface Pro 7 device is backlogged and there has been no movement since April 2022. The only workaround indicated is to use a mouse. This is the same workaround I’ve seen suggested in community topics for other Surface tablets.
https://github.com/brave/brave-browser/issues/16908#issuecomment-1105375466
Seeing a couple reports of this. Workaround in meantime is to suggest they use a mouse that can be connected to the device (such as a bluetooth mouse?)
I doubt if the issue will be fixed unless there is a large increase in the number of users having problems. Sorry I couldn’t help. Maybe another community member has a workaround and will post.
