Churchofengland.org problem
churchofengland.org: Menu button on left not working.
Testing the left side menu, seems to be working here. Does it work in private window mode?
Looking into this further, the Brave version is quite different looking from the Edge, Chrome and Firefox versions.
Sorry - the site I was looking at was biblegateway.com where the differences appear.
Hi,
Cached data may cause functionality issues. Clear your browser cache and reload the page. This can be done through the browser settings under history or by using keyboard shortcuts like Ctrl + Shift + Delete (Windows) or Command + Shift + Delete (Mac). Make sure that JavaScript is enabled in your browser, as many interactive features rely on it. Additionally, ensure that your browser allows cookies, as they are often used to store session information. I got the same issue to this churchofengland real estate photo editing.org.
Thanks
