I would like to move brave files from C:\Users%User%\AppData\Local to new location do to its size on the disk How can this issue be reproduced?
Move the folder from that location to a new one and everything is now missing
when I move that folder to a new location I can 1. go into brave browser and change the location, or 2. have brave notice the move of that directory to another location and just keep working.
1.14.84 Additional Information:
Looking to free up space as that folder takes up around 11GB and I have other drives that have more space.
Sorry, you are correct it was not 11GB but 6.1GB, but still, I would be happy to know the command line to do that if I could as cut and past to a new location just gave me a blank brave screen with no settings. It is good to know that when moving them back everything shows back up again.
Did you accidently install a game in there? sorry i couldn't resist
The folder should contain files and folders not bigger than 600 MB !
I’ve never seen +11.000 files in any installation of brave, the last two months.
If this is not a question for a Dev/Admin ??
I do indeed have brave rewards enabled, as for extensions I have translator, Google Translator, Adobe Acrobat Reader and Metamask. I do not know of any of these downloading Videos or anything of that nature. I do suspect if anyone did it, Maybe the translation extensions download languages for faster translation but that seems unlikely. After looking after a reboot, I found it dropped significantly to 1.4 GB so the Idea it is a cash problem now looks to be be true.
I had not as I did that before rather recently and did not see much a change from the last time months ago I checked. everything that could be cleaned up was only megs in size and only double digit. I would still like to move that folder off C: thought if there is an option to do so. I have a 10 TB drive just looking for something to fill its storage capacity outside of course the new Cyber Punk that is coming out of course :).
