Can't set ecosia.org as default searcch engine
I added ecosia.org as “other search engine” but when I click on the … to the right of ecosia.org, the “add as default” option is grayed out, so I am unable to set ecosia.org as the default search engine.
Is there some way to use ecosia.org as default? (they plant trees when you search - good for the environment!)
This may help https://support.brave.com/hc/en-us/articles/360017479752-How-do-I-set-my-default-search-engine-
