Camera permission is required to paste a code?
When attempting to join a sync chain, I’m asked to allow camera access despite the fact that I have a code in my paste buffer and intend to paste it.
This is on the android version of brave running on a chromebook, both current as of today.
  1. Remove camera permissions if you’ve previously given them to Brave.
  2. hamburger → settings → sync → “scan or enter sync code”
    At this point you will be presented with a modal dialog asking for permission to use the camera. If you decline, you will be kicked back to the previous menu without any option to paste a code. The only way to get to the “enter code words” option is to allow access to the camera.
Given above.
Camera access should only be requested prior to scanning, not prior to code entry.
Every time.
ChromeOS 128.0.6613.161 Official Build, 64-bit
Application version
Brave 1.69.164, Chromium 128.0.6613.127
Operating system
Android 13; Build/R128-15964.58.0
