Bug or problem with many site
bug
Hello,
I contact you for report a bug with Brave.
When i go on website with Brave, them has problems there.
For example, i go on “Lyric Streaning” who is a website who play a music whith youtube, videos do not start even if shields are lowered. Or, when i go on “Francebleu nord”, I also have problems whith Brave…
I try with firefox and i don’t have problem…
Regard,
Sim59121
Hi Sim,
The stream at https://www.francebleu.fr/nord is working for me, both on the new browser (https://brave.com/download-dev) and the current browser (Brave-muon). (Ca marche pour moi sur MacOS.)
You are on the new developer version, correct (0.55.x)? Or are you on 0.23.x?
Normally embedded video and streaming will not work if you are on the current browser (0.23.x) and have Strict Site Isolation enabled in about:preferences#security.
If you could provide more information about your system, that would be great.
Thank you!
#3
Hello,
I have check and the “strict site isolation” is enable.
When the “strict site isolation” is disable, the stream is working.
Thank you for your help !
#4
