Brave Will Not Clear Cashed Data For Specific Website
I use Brave on a Windows 11 Pro PC. I also manage a website. Whenever I update anything on my website, Brave refuses to show the updated page, but rather continues to show the cashed or old site data.
I have in the past, cleared EVERYTHING and sometimes it works. But I use this browser for other work and it is annoying to have to clear EVERYTHING just to update one web page…
I have followed how to clear data for a specific site, but it does not work. What might I be doing wrong?
PS: I have several other browsers, so I might test my site changes in each. All the others seem to more easily clear the data and show the updated page(s). Brave will not…
Ctrl+Shift+F5 should reload the page bypassing the cache.
Thanks Mythical5th, but that does nothing on my machine. No response…
Sorry, I got confused. F5 is the equivalent of Ctrl+R, and if you add Shift then it will ignore the cache. So you need either Ctrl+Shift+R or Shift+F5.
Thanks Mythical5th, that did the trick!
