I’m using a Samsung Note 9(Android 10; Build/QP1A. 190711.020) on Brave mobile browser (Brave 1.36.112, Chromium 99.0.4844.51), and my balance in the triangle icon says i have a balance of 27, but when i back it up in the Brave Wallet tab, it shows up as 0; my phone screen is broken and i have a week to return/replace it before then so I’m trying to get this fixed asap, thank you.
)? Android 10
Is your browser wallet currently verified? (yes/no) no
**What date did you verify your wallet?**n/a
**Have you been able to successfully receive payments in the past?**yes
Are you using a VPN? (yes/no) no
Are you in a supported region (see here for list of supported regions)? yes
Does your device pass the SafteyNet check (Android only)? yes
Have you manually turned off Auto-contribute on all of your devices linked to Uphold?? yes
