Is Brave sync workng?
Impossible to setup and impossible to understand. Chrome is so much easier. Why Brave neede to complicate matters so much?
Hello there ,
Yes, Brave Sync
does work. Sometimes there are problems, yes, but most of the time it works flawlessly.
The configuration is also not that hard to do. There are only a few steps involved to get it to work.
Steps:
- Go to
brave://settings/braveSync
in your address bar. - Create a new
Sync Chain
- Copy the words somewhere where it is safe, for example your password manager
- Copy the words over or create a QR Code and scan it with your other phone, laptop or pc.
- You’re done
When you need further or a deeper insight to set up this, let me know, I would try to assist you.
@Kavi,
Our documentation on Sync should help you understand how to set it up as well as how it works:
