It’s showing the same for more than 2-3 weeks, I thought that next update would fix it but it wasn’t solved.
Thanks for reporting @MFK. What OS and Brave version are you using?
Brave 1.5.7 and MIUI Android 9
And what happens when you click the X
button at the top-right of the message? Did it appears again when you try to tip?
Yes it appears whenever I reload or restart the brave
