So guys, I recently started using a new DNS server (NextDNS) on my devices and a few weeks ago my account got flagged for the first time.
I use Uphold.
I’m thinking NextDNS is blocking some Brave browser connections and other Brave stuff.
I can’t connect to grant.rewads.brave.com. The address is in my white list, like another addresses from brave.com
Is there anything I can do in my NextDNS configuration to allow other Brave Rewards related addresses to avoid this issue? It looks like NextDNS is causing the problem.
What Operating System and Brave version are you using
Version 1.49.120 Chromium 111.0.5563.64 Official Version 64 bits
Yes
Are you using a VPN? (yes/no)
No
Are you eligible for Brave Rewards ?
Yes - Brazil
**Are you on the list of supported regions when verifying Brave Rewards with a custodial partner **
Yes - Brazil
Have you manually turned off Auto-contribute on all of your devices linked to a custodial partner?
Yes
