Briefly describe your issue:
As the deadline to connect a custodial account approaches, ive been trying for weeks to connect my account. to one of the accounts and cant.
What Operating System and Brave version are you using? (Menu --> About Brave)
operating system im using is windows, version 1.520.130
Who is your verified custodian? (Uphold/Gemini/bitFlyer)
none
Are you in a supported region? (see here for list of supported regions)
yes
@Wrightkigame nobody can help if you don’t provide more details. For example, what message are you seeing when you are trying to connect? Are you trying to connect to Uphold?
This is way too old. You need to update. You can’t use Rewards if not using update Brave. (you are saying Brave 1.52 version, right?)
