Brave Rewards for September not credited into Gemini wallet to date. Same issue as brave rewards for August
Briefly describe your issue:
Hi there
I have encountered the same issue this month-i.e. despite linking my brave rewards to gemini, my BAT has yet to be credited into my Gemini account to date. This was the exact same issue that I encountered in September for my August Brave Rewards. Really appreciate the assistance!
Version 1.30.89 Chromium: 94.0.4606.81 (Official Build) (64-bit)
Yes
31 Aug 2021
No
Are you using a VPN? (yes/no)
Yes
Yes. Singapore.
Yes
Hi there any updates from the moderators would be greatly appreciated.
