Brave Publish Channels are showing wrong and diffrent Tipping Ammounts.
I want so set the Tips Ammounts to Default Values of 1,5,10
There is no Option in Brave publisher to set the Tip Ammount to Default.
There is no Option in Brave publisher to set the Tip Ammount to 1,5,10.
If i choose and set a predefined Ammount (1,10,100), it is added additionally to the Choosen and will look like this:
I have the same Tipping Ammount in all Channels. See here:
If i go to another of my Channel the Tiping Ammount looks like this:
- Go to www.erlebniscon.de see the tip ammounts
- Go to www.twitch.tv/bararizzle see the tip ammounts
Both Channels are mine and the Tipping Ammount is set generally to all.
If you use different Operating Systems (IOS, Android, Linux, Windows) you will see diffrent Tipping Amounts an every OS. Like Random Choose.
I use the same Tipping Ammount on all Channels, but every Channel shows diffrent Tipping Ammounts.
(Yes, the last save of the Banner was 14 Days or longer)
Showing the same Tipping Ammounts in all channels as configured.
Allways
page in the main menu):
Windows 10 latest Updates, 64 bit with Brave 1.11.101
Please reset all Tipping Ammounts to Default Values (1,5,10) for all my Channels.
