Brave problem with reCaptcha
windows
Brave seems to have a problem with reCaptcha. They appear to be an un-clickable object similar to a picture. Double and more clicks onto it only seem to mark the iFrame.
Picture:
recapcha%20not%20working
I’m running it on a Windows 7, 64 bit
While usually it’s no problem, some websites require the user to complete such reCaptchas to log in, at which point for now I had to switch browsers.
Hi @PCK4D,
Please check if you have Site isolation enabled under Preferences > Security. This setting may causing an issue with reCaptcha.
Thanks
:slightly_smiling_face:
#3
That was it, many thanks!
#4
