Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
- How do I opt into Brave Ads?
- Why am I not seeing Brave Ads?
- Windows 10 Ads Troubleshooting
- Rewards FAQ
Briefly describe your issue:
)?s/no)
Do you need to be brave premium to be eligible for payout.
(Yes/No)
Are you using a VPN? (yes/no)
