Unable to browse Google maps in 3D mode in Brave, on MacOS 10.15.7 and ubuntu 20.
3D works in Chrome on both platforms. I’ve tried enabling/disabling “hardware acceleration” in Brave settings and relaunching, no good, the 3D option is still not enabled in google maps.
For example: https://goo.gl/maps/fuaofKyAukTfbutx6
Turned off Shields, same behavior.
no
yes.
Brave version (check About Brave
1.31.88
