Brave not respecting search engine choice on spotlight search
Description of the issue: In my settings I have my default search engine set to DuckDuckGo, when I go out of the app and go into a the spotlight search on my phone and search something via that menu it will open the app and search what I typed on Google instead of DuckDuckGo.
  1. Go into settings and change default search engine to DuckDuckGo
  2. Have the Brave browser set as the default browser on you iPhone.
  3. Open up the spotlight search and search for something and then it will use Google for the search.
Expected result: For it to respect my choice and use DuckDuckGo
Brave Version( check About Brave): Version 1.78.1 (104)
Mobile Device details iPhone 14 Pro Max on iOS 18.5.
Additional Information: N/A
@HeyImLeo
See
Google used in my search results when google is disabled - #5 by Bookusher
