Brave Nightly Browser is shutting down every time I click on “Rewards Settings” under the BAT sign on the top right side of the screen.
1 - I click on the triangle symbol
2 - I select “Rewards settings”
The browser just closes itself out
See the rewards page
Every time I tried today
Brave Nightly
thanks for the bug report. I noticed the same on the dev channel and opened a bug report on github.
Can you confirm that Brave also crashes if you click on the shields icon?
And another question (just out of interest). If you in general shut down your system with open tabs and reboot and then start Brave are your tabs still there. I noticed in the dev version as well that they are away and I now get the message “Do you want to restore your tabs” instead … If I click on restore, they will come back obviously (it’s still annoying)
EDIT: I actually saw that your problem is slightly different. Your browser crashes after you have seen the popup right? (if you click in the popup on Brave Rewards). Mine closes directly if I click on the icons. Does it work for you to open brave://rewards in your search bar?
same issue here, running Version 0.70.57 Chromium: 76.0.3809.100 (Official Build) nightly (64-bit), as per roadmap, 0.71.x should be already available since yesterday, but I’m not able to update
anyway, hopefully, this issue will be fixed in next release
I just uninstalled the nightly browser. where can I get an updated version?
sorry the stupid question, I’m trying to search here in the community but without success.
