Brave keeps using the wrong search engine
Look, I can’t find anything to help me with this issue. I have searched, trust me.
And I don’t have a gazillion steps to reproduce or any of that that would necessitate an entire report.
I’m using updated Windows 7 and Brave 0.23.39. Brave just updated itself as well yesterday, so I highly doubt my version is obsolete yet.
Randomly, whenever it feels like it, Brave will go to Yahoo! when I search from the address bar. I’ve had Google set as my preferred search engine from the beginning. I don’t like Yahoo!. I don’t want it. I wish Brave didn’t seem to like it so much.
Looks like a bug to me.
Hi @Geo,
Can you share a screenshot from Preferences > Search?
Thank you.
:slight_smile:
#3
#4
Thanks for the screenshot @Geo! :slight_smile:
It seems you already set Google as your default search engine. It strange that it show the result from Yahoo! instead of Google.
  • Can you share about how you search from address bar? Additionally, a record of this issue is better. You can use LICEcap – http://www.cockos.com/licecap/ – to record it.
  • Did you accidentally type :y before your search keyword?
#5
You’re welcome. It’s always been Google. Pretty much anything I search for on my laptop is related to programming. Google turns up the most information, I find.
I type a search term in the address bar and hit Enter. Recently, I’ve been searching for help on doing things with PyQt5, a widget set for Python. Something like “PyQt5” QTreeview edit function would be a typical search I would do.
I would try to record it, but as I said, it’s random. I don’t know when or how it will happen again. I guess I can report back the search term or try to reproduce or something next time it happens and report back.
No, I can’t imagine a scenario where I would type :y before a search. I’ve never indicated I want to use Yahoo! for anything. This is strange and very unwanted behavior. I can’t imagine why it would be intended, so this is a bug until someone can give an alternative explanation.
#6
I’d also like to add that this is also RECENT, like in the last month or so.
#7
cc @Mattches or @sriram in case they know similar report.
#8
I can only imagine this happening because : is right below P button so when you are typing Py it might have accidentally typed :y but do keep an eye on it and report back if you see it consistently.
Make the shortcuts for certain search engines configurable!
#9
I thought exactly the same thing but thought it might be a little too outlandish to suggest :joy:
#10
This could be easily subverted if there was a way to change the shortcuts to call a certain search engine - but there is none, yet, is there?
#11
Unfortunately this wont be fixed on current muon version of browser-laptop. We are moving to a Chromium UI fork called Brave Core which will support customizing existing search engines and the custom ones you add. This should be available in coming months so hang in tight.
#12
It would be more like ":y since I pretty much always specify “pyqt5” because PyQt4 results are often not useful because there’s so many differences between versions.
