–Today I got a notification letting me know -that Brave was using- excessive data. When I checked the mobile data it showed it used 1.43GB so I checked Wi-Fi it showed it used 20.86GB of data. I am not sure when this started but my mobile -billing starts on the 15th of each month so this has happened with in the last few days. The only thing I can think of is that I just updated the app. I also tried setting up sync from my computer to my phone but don’t think I did it right as it didn’t seem to work. I also went into settings to try and turn off sync because it was the first thing I thought of that could of been the problem but it did not seem to be on. So just not sure what is going on. I also closed all my open tabs just in case that had something to do with it. I also restricted background data to try and prevent the problem. Any help would be appreciated. —
I don’t know how to recreate this problem.
Stop Brave using so much data. –
Brave 1.12.113 Chromium 190711.020
On Samsung S10±----------------------------------------------------
Mobile Device details
