Brave is blocking parts of our web application due to the file names used
Brave ( Version 1.8.95 Chromium: 81.0.4044.138 (Official Build) (64-bit)) is blocking parts of our web application due to the naming of some files
Create an AngularJS web application that contains beacon or push-notifications in the route
Brave doesn’t block any of our non-tracking web application
Every time
All. This is web browser related and not OS
If I access my web application, when it’s running locally and without any file minification, then multiple files are blocked by Brave:
  • localhost:9000/scripts/controllers/push-notifications.js
  • localhost:9000/scripts/services/push-notification.js
  • localhost:9000/scripts/services/beacon.js
  • localhost:9000/scripts/controllers/beacon.js
  • localhost:9000/views/push-notifications.html
When we build our web application for production, minification happens on all JS code and they are combined into a single JS file but the HTML views remain unchanged in their filenames. Accessing that minified version of the web application then only has that non altered HTML file blocked:
So this clearly seems to be an issue with Brave automatically blocking any files with the word “push” or “notification” and/or “beacon” in the file name
Hi,
I’m the filter engineer for Brave, there is probably no easy fix on Brave side for sites developing notifications/beacons/tracking etc. I would recommend just disabling shields on the site (localhost).
We block those elements due to privacy and annoyance, all 3 are related to push notifications and tracking (beacon.js).
This seems a little silly
We cannot ask our potential and actual users to modify their browser settings to access our site
It also seems a strange method from Brave for blocking. If I were adding tracking to my site and I noticed you were blocking files of a certain name (beacon etc) I would just rename my beacon files to avoid your blocking, which is what I am preparing to do at the moment, in our non tracking site which you have misidentified
Potential and actual users? they won’t have access to localhost. And if its a web notification or a tracker, it should be blocked. “beacon.js” is a commonly used tracker script.
Using localhost was an example to prove that these files are definitely being blocked by Brave
When I run my web application locally, none of the files are renamed. When the web application is deployed to our-web-application.com then the files are renamed (due to minification) but our view templates aren’t renamed, so Brave still blocks push-notifications.html
These aren’t web browser push notifications. Push notifications is a section of our web application that allows users to create a mobile phone push notification to their Android/iOS apps
How is blocking that effective long term? It’s not my place to judge your methods really but if I were trying to sneak past your defense, I would just rename my beacon.js file to nothingToSeeHere.js …
I’m just annoyed that I need to break my innocent web applications naming rules to support Brave users
