Brave on iOS is consuming a large amount of system resources and writing over 1 GB of data to disk even on days with little to no usage. This has occurred for 4 consecutive days, and I’m experiencing significant battery drain as a result. The issue seems to happen in the background, and system logs show repeated disk write warnings tied to the Brave app.
- Open Brave normally (no specific heavy use required).
- Leave the phone idle or use it lightly for browsing.
- After several hours, battery is noticeably drained, and iOS logs show excessive disk writes from Brave.
Brave should not excessively write to disk in the background or cause rapid battery drain, especially with light or no usage.
**Brave Versio
1.78.1 (Build 104)
Mobile Device detailsiPhone 15 plus
iOS 18.5 (Build 22F76
Last logged event was yesterday 6/15/25
