Brave freezing when right-click on bookmark folder
Visual representation of my bookmarks:
Streaming/
├── Amazon
├── Free
│   ├── Crackle
│   ├── Plex
│   └── Tubi
├── Max
└── Netflix
I have a folder on my bookmark bar called Streaming, if I right-click on it and then Open All, it will open Amazon, Max, and Netflix just fine.
But if I right-click on Free, the context menu does not appear, and I can’t click anywhere else on the browser except for one of my bookmarks.
That will close the suspended bookmark menu, but I can’t get Brave to open all the items from the Free folder.
Apparently, that’s an old issue, but this post is closed
When I right-click on the menu I get the error below on my terminal:
Dec 05 17:24:04 fedora gnome-shell[136535]: Buggy client caused popup to be placed outside of parent window
Version 1.73.91 Chromium: 131.0.6778.85 (Official Build) (64-bit)
@peagravel,
Can you tell me if you have any custom themes implemented at this time? Additionally, whether or not you have any extensions installed in the browser at this time?
I have no themes installed. I use gnome vanilla. Regarding browser extensions, I do have some, but now that you mentioned I disabled all of them and also tried in incognito, but no dice.
Now running
Version 1.73.104 Chromium: 131.0.6778.204 (Official Build) (64-bit)
the issue seems to be fixed.
I said it too early. The issue is back.
If the folder is shown on my bookmarks bar, I can right-click on it
But if there’s not enough space and the bar is collapsed, I can’t right-click on the same folder again
