- Open Brave using its shortcut (from start menu or taskbar)
Brave opens
Version 1.34.80 Chromium: 97.0.4692.71
I’m using an unofficial package of Brave, since I’m using Manjaro, this one.
When I open the browser with the shortcut it opens, freeze and after 1 second it closes.
BUT when I try opening it directly from my terminal, with the command brave
it works fine. The shortcut is using the command brave %U
, I tested using the same command on my terminal and it didn’t crash.
After several tries with the shortcut, the browser usually works fine.
I sent the crash report from brave://crashes/. The error “ID” is f6d521e9-a338-4406-8d61-cd30d8a7fb37, might be useful.
