Hello, today I got a notification that your browser use my background camera.
What does that mean ?
On Xiaomi phones its just a nag/warning message to inform you that the “Can use camera” permission is set to on for that app. That means the app can use the camera but it doesnt mean its using the camera right now. Just disable the permission, you dont need it for Brave anyways. Unless a website tells you to make a picture.
@noname1, @Externet is correct. Nothing to worry about here and I blieve this is aknown xiamoi issue.
Okay, thank you for your help.
