Brave blocks Rollbar endpoint
Rollbar.min.js and rollbar.umd.min.js is blocked -— It seems sending data to Rollbar is blocked on Brave completely.
Any site that uses Rollbar, but here is an example
https://test-beta-amber-28.vercel.app/ (gotta refresh a few times to trigger error)
https://test-beta-amber-28.vercel.app/vanillajs
Screenshot of the ad as it appears in Brave:
There are no ads with Rollbar, just the errors getting sent to Rollbar
Did the issue present with [default Shields settings]
Yes
Yes
Does the ad appear when using a Private window as well? (yes/no) No
What OS are you using when you see the ad? Mac Sonoma 14.5
Version 1.70.119 Chromium: 129.0.6668.70 (Official Build) (arm64)
