Brave blocks my site's Javascript as "Ads and Trackers" even though they're not - and the same files work fine on other sites
Brave blocks my 3 javascript files at https://clarity-delta.make.services (and clarity-master.make.services) even though the same 3 javascript files work fine on https://clarity.casperlabs.io. It appears the *.make.services domain is not trusted by Brave???
https://clarity-master.make.services
(but really, *.make.services as we’ll have this service up on other subdomains too)
Screenshot of the ad as it appears in Brave
There is no ad. Just a web app. The blockchain explorer for the Casper Network that we’re developing.
Did the issue present with [default Shields settings])? (yes/no)
yes
yes
Block ads and trackers will break the site.
yes
1.19.92
THANK YOU!
Michael Steuer
Fixed (give it 24-48hrs). Clarity is a tracking company which is why its blocked
“Clarity” is the name of a tracking company? So anything with “clarity” in it will be blocked by default? If that’s the case, would you be able to whitelist *.make.services? Or at least: clarity.make.services?
Thanks so much!
Sure, adjusted filter to cover make.services.
