Blogger.com Comment feature does not work
blogspot.com Comment feature does not work
Steps to Reproduce (add as many as necessary):**
1.go to this blog on blogger.com: https://nephicode.blogspot.com/2018/08/nearly-surrounded-by-water-part-iii.html#comment-form
2.scroll down to " POST A COMMENT" and write in “testing 123” or something.
3. Press Preview or Publish
Actual Result:
the webpage will go back to the way it was (actually sometimes it will jump to another page and explain there is a problem) The comment you made will not be there.
Expected result: The comment should be there. Try some other browser to see it work. Then delete your test comment.
Reproduces how often: I have tried to post a Comment with Brave probably 6 or 7 times. It has yet to work once.
Brave Version(about:brave):
Brave 0.23.79
V8 6.8.275.24
rev 51b4905
Muon 8.0.7
OS Release 10.0.17134
Update Channel Release
OS Architecture x64
OS Platform Microsoft Windows
Node.js 7.9.0
Brave Sync v1.4.2
libchromiumcontent 68.0.3440.84
Reproducible on current live release (yes/no): Yes (as far as I can tell my release is the current live release. I downloaded it 2 days ago.)
Additional Information: keep smiling :slight_smile:
