Block script and block regional ad by default
Hi,
No matter how many times I set block regional add in the preferences, next time I go it is unchecked again.
I Would like script blocking to be set by default, could you add a checkbox for that in the settings!
Thx
Hi @ociviol
For 1, are you still experiencing this on the latest version?
For 2, if you go into Settings > Site Settings > JavaScript and toggle that ‘off’, when you open a site in a new tab you will see ‘Block Scripts’ enabled on your shields.
Thanks,
Lauren
closed #3
